Texarkana
cajunjerry
Springhill,La.
Does anyone know what is going on with the Texarkana TRS system? I can't pick them up anymore even when Im in Texarkana..System on scanner is not locked out
safetyobc
South Arkansas
Have you set the new rebanding frequencies? Or have a scanner that is capable of being rebanded. The system was rebanded recently.
cajunjerry
Springhill,La.
I have all the frequencies in that are listed in the database..6 months ago I was in Texarkana and heard everything just fine.. My scanner has been rebanded...
INDY72
Indianapolis, IN
OK updated to what is licensed currently for the TRS. We need new CC's, ACC's, Connect Tone, and ANY TG changes. TY in advance.
cajunjerry
Springhill,La.
So those are the new rebanded freqs you posted? Over a year ago it said rebanded and I put those in and it worked..I will now put in the one you posted today...Jerry
cajunjerry
Springhill,La.
Wait a minute.All of those freqs that are new posted in the data base are all the same but one
859.23750 The others were the ones that used to work..Could that one new one be the whole source?
AF5JQ
Wake Village, TX
The frequencies and talkgroups listed in the database are current. If I recall correctly, 856.2375 and 857.2375 are the primary and secondary control channels.
INDY72
Indianapolis, IN
OK guys, what is needed is someone to actually go monitor the system, (currently) and submit what they find. That way we actually have the best verified data. TY
AF5JQ
Wake Village, TX
I monitor the system daily, and have been for years. What's in the database is correct, the only thing I'm not positive on is which ones are the control channels, which alternate every day or two so I'll have to check that out.
INDY72
Indianapolis, IN
TY CC's AC's, Connect Tones, SysID's... Thats the kind of data that we look for. :)
AF5JQ
Wake Village, TX
That shouldn't be happening. I'm listening to it as I type this and can hear everything. 859.2375 is the control channel at the moment, and the talkgroups listed in the database are what they say they are. Have you tried monitoring any other trunking systems? Shreveport is also a Motorola Type II, you might see if you can get anything from there.
INDY72
Indianapolis, IN
OK should still be 105.88 Now all we need is the other 3 CC's... TY that pretty much confirms the system is accurately listed. Cajunjerry, your iether misprogramming, or having issues with your scanner. I would definitely try other Motorola II's and see how its working for them, specifically rebanded ones, and also non rebanded... Entergy, Shreveport, Bossier City etc..... What kind of scanner are you running?
cajunjerry
Springhill,La.
I run the 396T 996T
A year ago I was able to hear Texarkana..had my scanner rebaned when Shreveport rebanded..No problemns hearing Shreveport
