Texas American Strong Flyover May 6th
nd5y
Wichita Falls, TX
We already had one here and SW OK last Friday.
kv5e
T¹ ÆS Ø
141.175 AM has been confirmed in other flyovers with the joint TB/BA aircraft operations in the NE. Might want to monitor that as well as other TB/ BA listed frequencies in the WIKI
Air Show WIKI
Starting on page 68 and going to the end of this thread below has the frequencies they've been using for air to air and refueling. Though it is good to monitor all of the Blue Angels and Thunderbirds freqs just in case they change.
hiegtx
Mentor
Dallas, TX
More details are supposed to be provided tomorrow, May 5th.
This article has a little more info, including a map of the intended flight path, and the timeline for it. Not sure if I'll be able to see it. They would pass by my area off to the east, but if not high enough, trees may block what I can see. Once they go far enough south, around Midlothian, then turn back northerly, they be on the other side of the White Rock Escarpment, and visibility would again depend on their altitude & trees.
KI5IRE
Oklahoma City
So what frequencies should I monitor for this today? I was planning to program the Blue Angels frequencies in the database, but are there any others I should program?
rbarker
Robert
Austin, TX
please post the frequency for the actual use. I don't care about refueling. I see the lists but i don't understand the Diamond, the solos and the start up. it's just a one formation fly over. I don't think there will be a need to refuel since this they can land and fuel.
They will not land to refuel, all flyovers have inflight refueling.
Blue Angels freqs used at other flyovers were:
284.25
289.80
237.80
You might also hear them on your local ATC and airport frequencies.
Blue Angles Pre-flight brief live on their Facebook page
hiegtx
Mentor
Dallas, TX
Using 284.25, one of the 'Diamond' on the DFW flyover.
hiegtx
Mentor
Dallas, TX
Yep, too tight a schedule for landing to refuel. They'll end the DFW flyover @ 11:35am, then the Houston pass is scheduled to start at 12 noon
hiegtx
Mentor
Dallas, TX
Anyone get audio?
I did not set up to record audio, but there was only a small amount of traffic during the flyover itself. The flight leader was advising the others to add, or reduce, power, also giving brief cues to making the turns scheduled or changing altitude. I did not try to monitor refueling. I presume they fueld either just before they arrived here, or whill enroute from the DFW area to thext flyover in Houston.
tunnelmot
Conroe, TX
Nice job @tunnelmot music was a little loud but very nice video and edit with comms.
Thank you sir!
Sorry about that. I spent over an hour adjusting the audio between the radio traffic and the music. I achieved perfection...until I uploaded it to YouTube then the audio was all over the place. IDK what happened between final edit and upload. I agree it was loud and wasn't what I intended.
