"The Feature Set does not match" "Error Context: 2a, Status: c0001012" when attempting to write config file. When I searched on the Internet, I only found one link, which does not answer my question at all.
I just received two Motorola H18KEC9PW5AN which is VHF 1-6 Watts ASTRO XTS 5000 Model I (from someone on an online auction and sales site). That's consistent with what was ordered, so far, but we'll see.
Now, in ASTRO 25 Portable CPS Version R20.01.00 (which I bought on a Motorola DVD), I can easily read the configuration from both handheld radios in the CPS software, but when I try to write the configuration to the radios, both give the above error ("The Feature Set does not match" "Error Context: 2a, Status: c0001012"). This happens even if I did not change anything in the configuration at all. (At first, after reading the radio I had fully configured the tree then tried to write it; I got the error, so started fresh from the radio config and tried to delete just one channel and its scan link, then tried to write it, which also gave the error; then finally, I tried to write the same configuration I just freshly read from the radio with no changes. All gave the same error.)
It shows FLASHcode "100001-000000-7". The Current Feature Set shows exactly two items: "H35 Conventional Systems Operation" and "Q806 ASTRO Digital Operation". Under "Radio Information: Tracking", it shows Original Programmed Information: Date "03-Oct-2003", Codeplug Version "0008", Source "Factory"; and FLASHport: Times Flashed "0", I-Button "000000000000", Last Source "Factory". Last Programmed Information was in 2004 from CPS when I first got it, but now it says today. Versioning shows Codeplug 0024.
I've never flashed a firmware onto a Motorola XTS or XTL radio, so I don't know what that entails. I have successfully configured both an XTS2500 900MHz model III in ham bands and an XTS5000 VHF model III in ham bands, and both work with respect to the software (my older VHF XTS5000's output amp blew out).
So, what are my options? I want to write a configuration file with my local channels, obviously. As I said, I have CPS R20.01.00. I don't have anything that says it is a flashcode file, but I don't know what they look like, so maybe I do, and maybe I don't.
