Merovingian
- Joined
- Sep 17, 2006
- Messages
- 206
I have been interested in RF reception for a long time but it usually takes a backseat to my digital photography and astronomy hobbies. Over the last few years I have been putting my time, attention and especially money into photography and astronomy equipment. I have decided to take a brief rest from that to boost up my radio reception equipment. I have had an Ettus B200 SDR for a few years but didn't use it hardly at all because I have no outside antenna, I bought several small screw on antennas for it but I was only ever able to receive the strongest FM radio stations. I got bored with that and put it away for the last several years. Last week I ordered an SDRPlay RSPduo receiver mainly for receiving shortwave, I'll use it for receiving 1kHz-70MHz and I plan to let my B200 receive it's range of 70MHz-6GHz.
I am planning to buy a Wellbrook ALA1530LN NA active loop antenna to use with my SDRPlay RSPduo and I was thinking of installing some sort of discone antenna for B200 to cover the 70MHz-6GHz frequencies to receive whatever is out there. My problem is at the moment I want to be able to receive everything because I don't know what I want to listen to yet. I would like to listen to civilian aircraft, military aircraft (if any are around), police, fire, ect. . . also amateur radio, satellites (I know that takes a different type of antenna) and other things I don't even know is out there. I've done some reading about discone antennas and it seems I may have to put up two or three antennas to cover the majority of frequencies since the published frequency range of the discones don't really cover what they say they do.
A few years ago I bookmarked a post I read here made by prcguy, I was impressed with his description he gave of his discone antennas he frequently uses.
https://forums.radioreference.com/threads/discone-reception-questions.360388/post-2830913
He stated: "my go to antenna(s), which I'm using right now on my new Icom R-8600 is a a pair of Discones, one covers about 100 to 800Mhz and the other about 400 to 3,200MHz combined with a diplexer with a transition in the 600Mhz range." I would be very interested to know the brand and model of antennas he is using along with the brand and model of diplexer. His setup sounds like it would cover what I would like to listen to.
I have no experience with using all of the various antennas available so I have no idea what antennas would and would not work with what I want to do. I will probably need at least 2 if not 3 antennas to perform decently in the large range of frequencies I want to explore, then trying to use them all on one SDR receiver is another challenge.
At one point I was thinking of a discone with multiple vertical elements tuned for the various frequencies instead of one long whip on top.
I don't know if this is useful or useless.
Here is another one with multiple elements
I saw this today. It is similar to the first picture.
I don't know if any company makes this type or not.
I have heard that this Antennacraft ST2 was a pretty good antenna
It is apparently not made anymore.
Prcguy seems to be a super guru in this field, I'm hoping he can pass along some information and I hope anyone else with experience in listening to what is out there can give me some advice on what antennas I can install and what else there is to tune into beyond airplanes and police/utilities.
Thanks in advance to everyone.
