Thruway P25 Phase 2 System
seagravebuff60
Short Bus Reject
I doubt this new Harris system for the Thruway will allow other agencies besides those who work and parol the mainline Thruway and the spur routes. It seems that just like the MTA/MRRS system, this system will be designed for specific coverage immediately around the thruway and nothing else. It is not true, "Statewide," as the article portrays.
Just an FYI, what I mean by a true statewide system is a P25 System that can mostly blanket the whole state with coverage and allow multiple users on the system, not just the state entities. Systems like NJICS in NJ (as you mentioned), CLMRN in CT, and Starcom in IL are perfect examples of this, and many more.
I will add to my statement above. This system seems that it will be designed for specific immediate coverage around the thruway and generally won't be receivable away from the thruway. Kind of like how their UHF system is designed now. I would expect this system to have a handful of TGs assigned to the NYSTA and a few TGs assigned for NYSP Troop T. Hell; they may even share the same TG as they do "Channel" now on the UHF System. Yes, it will be statewide, but "statewide" in the sense that it will only follow the thruway statewide, as @k2hz points out in a previous post.
I'm not sure why "Pennsylvania did it, why can't NY?" is being held up as an example, since it looks like four out of 67 (if I counted right) counties are using it. What would be the advantages to the individual counties and cities of having a single state-run system instead of them being able to implement what's best for their needs? If the argument is, "Well there should be a statewide system for the state police", why? What advantage would that provide in Monroe County?
I would not get to hug up on me mentioning PA. It was a generalized statement that they have a "statewide" system. Maybe not a lot of other agencies except the state ones are on it, but they do have a theoretical "statewide" system.
In most counties in Central NY and the Finger Lakes region all law dispatch has been centralized at county level 911 centers for many years.
You call 911 and you get a response from the nearest or most appropriate law enforcement officer. No more deciding if you should call NYSP, the town PD or the Sheriff. With all LEOs on the same dispatch system immediate backup from the closest unit is available. What would be the point of NYSP having their own dispatch system? The expansion of regional systems such as CNYICC also makes a potential State system redundant.
The only NYSP VHF channel activity in this area is mainly administrative or internal units such as the BCI or the Commercial Vehicle Enforcement Unit.
Troop T is a special case since the limited access Thruway is generally isolated from the surrounding communities. The Troopers in Troop T are providing a contracted dedicated enforcement service for the NYSTA.
Great info. In addition, most counties in the Hudson Valley have a centralized county dispatch center, and they are one of the county's only (if not the only) PSAP. They handle most of the 911 calls that come in, primarily via cellphone, and often have a "Poling" channel where they will poll for the closest available police unit; that could be NYSP, County Sheriff, or local Town Police unit. Then, the call may or may not get transferred to the responding agency for further communication. In a select few counties, the state police will also handle the 911 calls and transfer them to the necessary agency, just like the county dispatch.
Also, some counties in the Hudson Valley operate completely differently and according to county-specific needs. But if anything, the coordination between the State, County, and Local police seems superb here.
NYSP patrols all major roadways throughout the specific counties, except the thruway or any spur routes, which, as you said, are handled by NYSP Troop T in their agreement with NYSTA. And yes, even here, there is a bit of an isolation aspect, except if a crash with injuries or entrapment requires an FD or EMS response.
k2hz
Rochester, NY
This is also a different situation since the Thruway, being limited access, is essentially isolated from the municipalities it passes through vs MTA with its stations and right of way embedded in the communities. There is minimal interaction Between Troop T and other Troops or county Law enforcement and no interaction with other Public Works. The only interaction is with Fire and EMS services that respond when Thruway dispatch calls the county PSAP to request a response. There is no interaction by radio. The units respond to the requested location and handle the incident while Troop T handles traffic control. Towing and roadside service is handled by authorized contractors dispatched by the Thruway and with Thruway radios in their vehicles.
MTA/MRSS has municipalities included in their coverage area and incidents in these communities can often involve both MTA and local resources so it is a "win-win" situation for some to use the MTA/MRSS system.
DaveNF2G
Latham, NY
WRUL880 is Ulster, Greene, Columbia and Orange Counties. There are several similar NYSTA licenses for other groups of counties along the Thruway. WRPX230 appears to be the license for whatever you are hearing in the Albany area. Site 3 is the NYSTA Headquarters.
I didn't look at anything further away than I thought I might monitor from home yet.
Based on the above, though, it looks like the licenses might be per Zone.
dave3825
Suffolk County NY
They are running a small P25 system in Albany. It seems to cover only their HQ at Exit 23.
Source? Because I don't see anything listed at all, so nothing has been submitted in RR.
FCC ULS and direct monitoring.
Not submitted because I can only receive it from closer to the HQ than where I live, so I don't have any details yet.
Yes, that plus WRUL880.
Has anyone in that area gotten any new info on this yet or made a submission?
DaveNF2G
Latham, NY
They are running P25 on 450 under the previously cited licenses. However, as stated earlier, I have only received the site at Exit 23 (HQ) and only from nearby. The main alternating patrol frequencies (453.425 and 453.525) are still analog.
GTR8000
NY/NJ Database Guy
BEE00
Okay, so what are the parameters of this new system that you've discovered? SysID? WACN? Control channel frequency and NAC?
And yes, the new system is going to be an L3Harris mixture of 700/800 frequencies with some simulcast cells in the counties just outside the city. 4 frequencies per site, TDMA.
Joshuascanner2021
I recently was in the area of two of the sites (towers) in the Rochester, NY area and NOTHING is transmitting yet on any of the 700/800frequencies. I checked about two weeks ago.
To be fair these licenses were just issued I believe in March.
ak716
'Merica
NYSTA has signed a contract with L3Harris to build out the proposed P25 700/800 system over the next 3 years.
"Muller said the P25 deployment is expected to take three years. The first phase of work will involve installing about 1,300 XL-200 mobile radios into authority trucks and other vehicles.
Years......we're years away....
DaveNF2G
Latham, NY
The UHF system is relatively low power and its coverage is oriented along the Thruway. Any effective analysis will have to take place from the Thruway itself or very close by. Given NY's allergy to mobile radios in civilian vehicles (so-called "ham exemption" notwithstanding), it could become a risky proposition. Both systems have been discussed among hams locally, some of whom are actually connected to the State and/or relevant radio shops (we have a net for that) and they have different purposes.
UHF appears not to be trunked. They are just shifting conventional ops from analog to digital.
esfd283
Reminder, systems like the CNYICC and Finger Lakes exist because of the failure of NYS to created a statewide wireless network otherwise known as SWN.
seagravebuff60
Short Bus Reject
And so are a majority of the other local county systems in NYS that are depolyed. Why do you think NYS was obligated to build a statewide system?
nikronzo
NYS needs to take the example of Maine and MSCOMMNET. Harris built the system several years ago and for the rural geographic area it covers using VHF mountain top trunking, it works exceptionally well. There are of course issue and shadowing and just plan no coverage areas. However Harris proved that they can build it and maintain it, especially with the use of VoC.
NYS and Maine are very different political and public safety environments, but the point is it could work.
