yankees1013
- Joined
- Jan 21, 2011
- Messages
- 12
I can receive those agencies but I’m trying to get the Conventional frequency for the Thruway 87 Which is 453 .4250 or453.5250 Can’t get either or
It is and forever will be known as The Tappan Zee Bridge!
Have you tried "direct frequency entry" on the 436 to eliminate any PL or other programming issues?I can receive those agencies but I’m trying to get the Conventional frequency for the Thruway 87 Which is 453 .4250 or453.5250 Can’t get either or
I agree 100% with you!I Am Over in Northern Westchester, My 996P2 Picks them up fine. I Travel to the GSP every day and hear them well into Jersey as well. Check Your antenna to make sure everything is getting received correctly, then a common mistake is checking your programming and make sure you don't have them on Lockout or Avoid. I would also suggest going outside to see if you can pick them up.
I don't know why you keep asking people to "try it". Do you realize that pretty much no one else in this thread is in the Spring Valley area, much less Rockland County? Some are well over 100 miles away from you. The Thruway channels are working fine, something is wrong on your end. Find someone with a scanner to compare yours to, that's the only advice left to give you at this point.Can somebody try it today and see if it works ty
Maybe the New York State Thruway Authority isn't loaded into the database or you have the PL wrong.Thanks for all the feedback I’m giving up maybe the 436 just doesn’t pick up the frequency![]()
That is a negative... works fine on my 325p2.Maybe the New York State Thruway Authority isn't loaded into the database or you have the PL wrong.
That is why I suggested he try direct frequency entry and that apparently didn't work either.Maybe the New York State Thruway Authority isn't loaded into the database or you have the PL wrong.
They're running Harris radios, right? Any idea how to replicate this with the Kenwood NX5800?Vote scan. Higher RSSI wins.
