Thunder Bay Fire Department
vindictive42
Thunder Bay
5.1 Department Communications
Thunder Bay Fire Rescue Services has an agreement for fire dispatch with Thunder Bay Police.
All incoming 911 calls are answered at the police communication facility. Subsequently, the call
is transferred to the Fire Dispatcher and communicated to the appropriate apparatus.
The required key components essential in a successful call-taking/dispatch process are a reliable
radio communications infrastructure, well trained professional Fire Communicators, and a
strongly supported Computer-Aided Dispatch system. These components are critical in meeting
established service levels and providing firefighter health and safety at emergency scenes. The
present operating model of contracting services from the Police Communications
Divisions is 13 years old and has not been thoroughly reviewed since Fire Dispatch
ceased to be a function of Thunder Bay Telephone.
TBFR operates an analog radio system that uses a number of repeaters and towers to boost
and relay radio signals. Truck, portable and station radios are relatively modern, but supporting
infrastructure is antiquated with many components more than 25 years old, requiring significant
maintenance and repairs.
TBFR uses 4 radio channels. Channel 1 is the main operating channel. This channel is repeated
across the city and is both monitored and recorded by fire dispatch. Channel 3 is a radio to
radio Simplex frequency and is not repeated or monitored by fire dispatch. Channel 3 is a radio
to radio frequency that is repeated by way of an apparatus mounted mobile repeater. This frequency
was recently established in order to enhance communications during interior operations
at large structures where construction materials are detrimental to effective fire ground communications.
Channel 3 is also not recorded or monitored by fire dispatch. Channel 4 is an additional
tactical frequency that can be used during large scale operations or during situations
where concurrent emergencies are taking place. This frequency is repeated and recorded at fire
dispatch. However, the frequency is not monitored or answered by the fire dispatcher.
Finally, neighbouring communities in the Thunder Bay district are experiencing similar fire dispatch
and radio communication issues, and some to a much greater degree.
It is recommended that TBFR undertake the following:
RECOMMENDATION 5.1.1 Request an RFP to review the current dispatch model of contracting
Fire Dispatch, the radio communications system, and the computer-aided dispatch
system. Attention should be given to referenced and applicable industry standards
including NFPA and Provincial Public Fire Safety Guidelines.
scantbay
The system is older but seems to work for the most part that I have listened to over the years. The simplex channels are harder to pick up depending on where in the city they are being used and they don't seem to use them that often. I wouldn't be suprised if they do some type of upgrade independent of the police. The police system is digital provoice which has received many mixed reviews over applicability to fire operations. Additionally, the police and fire dept here don't seem to like each other too much, so a closer relationship doesn't seem likely. Whatever the outcome, I just hope they don't go encrypted and eliminate the hobby even further. As for the district, the surrounding communities outside Thunder Bay are dispatched by the CACC on analog frequencies outside of the fleetnet system. These communciations can also sometimes be spotty due to distance and terrain but the setup and relationship with the CACC seems to work very well with EMS first response and Fire Dept operations. A direct link to the OPP Comm centre via provincial common would be a good idea for these departments due to the distances involved and the fact that many times the fire depts are on scene ahead of the OPP. Just my thoughts.
