The freq are the same ones as seen in the database.,.,.,,again , the word I heard ( Sprectrum ) they will use existing freqs....and will now use DVP....this DVDBIR , not a trunked system , so there is no control channel.....just the same channels as before only diff is Digital Voice Protection....end of story....you can listen to the hiss , or white noise.,...every one in a while they do go clear for maintenance , etc....do a lil detective work.....listen for spectrum to show up , they will be analog....dong work in the future, they again , often they switch to clear mode ( variety of reasons ) - also tune into fire...and ems....if its a good call , youll hear it....also monitor the OPC 142.770 - Timmins pd still has to talk to the opp on joint ops....they always use that freq no matter , least in the north over the last 25 yrs in my exp.
last second thought use a p25 radio , listen to mnr....they will use opp and the city pd for joint ops , and all use 142.770 again mostly in north ont this method is used.,.a lil detective work here goes a long way.,,,,try the input...is there a hiss...I would say yes.,.however ya never know
