TIP: BCDx36HP Change Dept Hold w/ Active Site Hold
Steve2003
Colorado
One of the things I dislike about the site hold mode is you can't modify a department hold while it's in use.
One of the things I have discovered is a channel hold will keep the scanner locked on the current site. Here is a work-around to keep your site locked while changing your department hold:
1. Assuming you have an active site hold, press the CH button to do a channel hold.
2. Release the site hold.
3. Modify your department hold
4. Turn back on your site hold
5. Release the channel hold
Steve2003
Colorado
Good thinking, thanks for the tip. :)
This is really something I think a future firmware update should fix. Site hold and dept hold should work independently of one another.
-AZ
I would have liked to see the site hold be FN + System instead of FN + Dept since a site hold is essentially a "System Hold". Guess we'll see what future firmware updates have to offer!
