SargeAF
Greetings...new to the forum from the Atlanta area.
I recently acquired four type 1 (450-490MHz) TK-380 HTs (two Version 1.0 and two 2.0). I’ve programmed them for GMRS use and also monitor 70CM repeaters with transmit disabled (don’t have HAM ticket yet). I have flashed them with what I believe is the latest firmware for both versions. They’re very rugged radios, and I recently had a radio tech put them on his service monitor and check frequency deviation, and dialed in selectivity and transmit power...they work well and sound great.
I know that FleetSync was sort of a flop (commercially) but I’ve been playing around with it on a few channels to maybe use at events or while camping/hiking. I have set the fleet/radio numbers for each radio, and have them all programmed with the radio list with all radio IDs and Alph names, and have PTTID on and set to BOT, as well as having CallerID enabled. The CallerID works with the Version 2.0 radios (alpha name of transmitting radio shows on receiving radio while simplex), but it does not on the Version 1.0; does that only function on the V2 radios? The only way I can get a caller ID on the V1 radios is when you activate message mode and pick a radio name to alert and actuate the PTT, versus ID’ing on a normal simplex transmit/receive like the V2 does.
Also, I tried doing a Selective Call on both V1 and V2 radios, and the receiving radio is alerted and you hear the Selcall tones when you press the PTT, but my other two TK-380s on the same channel also hear the voice traffic. I was under the impression that SelCall would allow voice comms between the two radios selected (private conversation) and the other FleetSync radios on the same frequency would not break squelch...is this not the case, or am I missing something in my programming?
Thanks in advance.
Sarge
Thanks in advance.
Sarge
