TK-480 Scan
BigRedBox80
I'm trying to program a TK-480 that has two Systems. Each system has a number of groups (channels).
I seem to be lost on the scanning thing though. I want to be able to turn Scan on for System 1, but not System 2. No matter what I think I've tried, it seems to scan all groups in System 1 regardless if scan is enabled or not.
What am I missing?
BigRedBox80
To expand on this a little. If any of the groups in my system are set to "Grp-LOut" - "Yes" then the radio is constantly scanning whether or not I select the "scan" function. It may not display that it's scanning but any frequency in the system that receives signal the radio "stops" on it.
ramal121
Lots and lots of watts
Calif Whine Country
OK. Your model type is set as trunked. Even with conventional groups they are always scanned no matter what the scan button is set as. Group lock out in programming is the only way to modify this. Screwy ancient LTR logic.
My suggestion is to change the model type to conventional which will change the way scan works and you will keep your sanity. You will have to start from scratch however.
BigRedBox80
Is this where I would set to Conventional? I seem to be missing the option if so.
It gives me the option under other model types, but not the TK-480.
ramal121
Calif Whine Country
By gosh you're right. I just checked. The few 800 radios i dealt with were all trunked so I didn't realize. So yea it looks like you are stuck with that crazy scan function.
