TK-5410 programming
Omie09
I just got a Kenwood TK-5410 K2 model and I have learned the software. I programmed two channels, one P25 and one analog, both will not work properly. In a normal state, the P25 channel will only receive if monitor is on, even though the NAC tones are correct. The analog channel will not work at all and will actually revert to channel 1 zone 1 when the PTT button is pressed. However, in emergency mode, the radio performs fine. Does anyone know what I can do to fix this?
What is your source of programming info?
That behavior usually indicates the NAC is incorrect. Try programming the Receive NAC for F7E and see if it works correctly.
Is the Data box checked on the Analog personality? If so, uncheck it.
Omie09
The software won't let me uncheck it, saying "This personality is programmed to the data System-Personality Select the 'data' box.
I also would like to try trunking operation. I've heard how you can't, or it is extremely difficult to do NAS, so if the radio is inhibited, can you uninhibit using dealer software?
Omie09
You need to take that personality out of the data system.
You can't.
Just don't.
I understand why people don’t like to discuss this but I have a question. When I go to the talk group tab in the trunking system, everything is grayed out, including the hunt channel options. I have found many serial codes on the internet. Is this what determines if I have access or not, or the advanced network key? I have checked all trunking and TDMA capability boxes in the product information section. Even though I have played around with the software a lot, I am still pretty new to Kenwood programming.
buddrousa
It means you do not have the SYSTEM KEY from the ADMINISTRATOR and you do not have the RIGHTS to ENTER TRUNKING DATA.
You most likely are way over your head if you are asking these questions. If you have a LAGITITMATE REASON to be on this said Trunking System then have a System Administrator Program your Radio if not buy a scanner or SDR's and enjoy Receiving.
Omie09
Well that stinks. Would it work to put all the site frequencies into a scan list? Just don’t want to spend any more money. And just to be clear, I’m not planning on transmitting at all. No need.
Omie09
There are several threads here with this discussed.
Is it possible? YES
Is there risk involved? YES
Is there a chance that your radio will receive a KILL CODE and get Bricked? YES
General advice PROCEED WITH CAUTION.
Okay. I’ve done this with my XTS5000 and it worked somewhat. Hasn’t gotten bricked using the method said before. Hoping it works better. I am having a hard time looking for answers to my questions on the internet so thanks for the responses.
If you program each frequency for the trunked system in as a conventional channel, and click the "Receive Only" box, then add each channel to a scan list.
You'll need to manually take the control channel out of the scan list. They may change control channels periodically.
This will work, but you'll have a challenge following conversations, especially if its a busy system.
