tk-5710 station alerting
aaronhees
Missouri
I have a remote mount tk-5710 that I'm wanting to use for station alerting. I have done this using a Motorola CDM1550 but am not familiar with Kenwoods. The desired result is to make one of the D25 pins go to 12v+/- after a decode of QCII tones. Is this possible or is there any other equipment needed?
Also as far as programming can it be done via the DB25 or does it have to be done via the mic jack?
I haven't done it with one of these either, always used the CDM's.
I did look at this at one point. I think the "horn alert" function will do what you want. There might be more glamorous ways of doing it, however.
ramal121
Lots and lots of watts
Calif Whine Country
Yes the horn alert function is what you want to use. The output is in the 9 pin white molex connector on the back of the brick. It will go to ground on decode of a selective call and handle up to 1 amp. If you really need a +12 volt output, the radio can be modified to do this.
aaronhees
Missouri
This is exactly the info I was looking for, thank you! Do you know which pin or wire color it is in the molex?
