TK-5820 alignment procedure
wcu02mpa
Asheville,NC
I have recently acquired a TK-5820 P25 UHF 400-470 mobile ransceiver. I put it on the service monitor and it is showing almost 1KHz of frequency error. It was new old stock and in the box. While I am quite proficient of Motorola alignments, this one I am not. Can someone enlighten me on the proper procedure for this? I have the proper software and an R2670B for a service monitor. I see the auto-tune function in the software, but it isn’t quite making sense. Thanks
I'd recommend getting the service manual. It's got step by step procedures on how to align it. You should be able to find the service manual out there on line. If you absolutely cannot, I might be able to find my copy and drop-box it to you.
WB5UOM
Should be auto tune in test mode with service monitor in generate mode on channel freq....and the radio at proper temperature.
WB5UOM
I reread op post ...auto tune...
set your signal generator to proper rf frequency...give it 1uv or better carrier signal....hit start in the radio software program.
takes seconds to do...
you may see the frequency slider move up and down then stop...
I think then click Save or ok ( Im not looking at program)
Should be done...
then you can go and recheck freq as you did to start with
wcu02mpa
Asheville,NC
I think that might be the problem. I wasn’t putting out enough signal strength On the sig gen. I will get it set up and do it again this afternoon and report back. Thanks
AM909
Radio/computer geek
SoCal
-80 or -90 dBm is the usual recommendation – basically enough for a stable RSSI reading. The TK-5820 manual says -20 dBm, which seems like a bad idea (and 30 dB more than my trusty R2670!) unless they deliberately deafen the receiver in this mode. It wouldn't be the only instance of a 30 dB mistake in a manual, Kenwood or other.
