TK-630H programming troubles
OFD-14-109
Otsego, MI USA
Hell everyone I am trying, quite unsuccessfully, to program my TK-630H using KPG-7D software and a serial KPG-4 programming cable all I keep getting is connection error messages when I try to read or write the radio. I am using an old 25 MHz 486DX laptop running true format DOS, Any help or suggestion would be appreciated.
ramal121
Lots and lots of watts
Calif Whine Country
Are you putting it into program mode? Press and hold the left button on the bottom row during power up.
markclark
Nevada Range
I'm not sure if your software supports that radio programming. I use KPG-44D v 2.02 for my radios, which are Kenwood TK-690 series.
OFD-14-109
Otsego, MI USA
It should the programming matrix shows KPG-7D for TK-*30 models do the high powered versions use a different programming version?
wcu02mpa
Asheville,NC
Some ideas
Just some basic things. I have programmed many an X30 series.
Make sure the correct COM port is selected.
Try the cable on a different X30 to make sure all good.
OFD-14-109
Otsego, MI USA
I have it connected to Com1 and have selected that port in the software still can not get the software to read the radio I will try tonight to see if I can get it to read my tk-730/830 dual band setup.
OFD-14-109
Otsego, MI USA
I tried tonight to read/write to both of my *30 series radioand can not read any of them. I’m beyond frustrated I’m wondering if my programming cable is bad
OFD-14-109
Otsego, MI USA
Well that’s not the case my KCH-4 control head has a 6pin mic jack not 8pin so I do need the kpg-4 cable I’m lost anybody have any suggestions I really need to get this to program!
KK6ZTE
California
Are you programming from a native Windows environment or are you programming via Dosbox?
KK6ZTE
California
Which version of software are you running? I've had issues with different versions before. These older radios are a pain to program.
What is your timing? Are you powering the radio on, then putting it into programming mode before touching the software?
Have you tried selecting the other com port in the software?
OFD-14-109
Otsego, MI USA
It’s version 2.01 I believe and yes the radio is put into programming mode well before messing with the software and yes I have tried both Com ports. I have installed the KCH-5 upgrade and I am trying to write a new file to the radio. I tried reading/writing to my tk-730/830 dual band radio to see if maybe I messed up when installing the 16K eprom but couldn’t get it to read or write on that setup either I have used this computer on many late 80’s early 90’s era Motorola Radios so I know the Com ports work.
n2mci
Kingston, NY
Some other things I would look at: If the programming cable requires 12v (MAX232 design or equ.),
make sure there's 12v on pin 1 of the 6 pin jack..
Also, one of the signal lines (RXD) is tie to the Hook line, make sure the Hook line isn't tied to ground
some where so that the radio will always scan..
A long shot, but I've seen with some early after market cables, the jumpers on the RS-232 side.. See:
http://www.repeater-builder.com/kenwood/pix/kpg-4-and-kpg-46-programming-cable.gif
Good Luck, Pete
OFD-14-109
Otsego, MI USA
Are you sure it’s 12V to pin 1 my service manual shows ground goes to pin 1 on the 6pin connector and 12V goes to pin 2
n2mci
Kingston, NY
It's pin 2 if it's a 8 pin jack.. The link I posted has it as pin 6? I know it's the end pin on a 6 pin jack..
I got the info originally from the see service manual and I located the pin when I saw 12v on it.. I
Used this to build a cable..
Pete
OFD-14-109
Otsego, MI USA
Ok so the mic jack on the control head must have 12V on this pin? I thought you were talking about the 6 pin molex accessory connector on the back of the head.
cmdrwill
So Cali
Kenwood usually numbers the pins on the mic jacks backwards from US RG standards.
