TK-630H programming troubles
OFD-14-109
Otsego, MI USA
Her are the pics of my cable.
cmdrwill
So Cali
In the second, component side, photo you see a diode symbol in the lower right corner. The diode has the anode, plus side to the left. That would be where the external power would go. It may be the same as the one of the +V pads.
cmdrwill
So Cali
There seems to be a voltage regulator right near and connecting to the diode. A better close up may help.
IIRC there is 8 volts on the mic jack used for running the mic element. Not 12 volts. Still should power the RS232 chip via the regulator.
Kfred
Early, TX
I have a cable almost identical to the one pictured. will not program tk-730. if you feed voltage into the regulator that is powered by of the computer port won't that damage the port?
cmdrwill
So Cali
I think that is the problem, trying to power the programming cable's RS232 to TTL chip from the serial port/computer.
My older Kenwood cable has a diode so the 8 volts does not back up into the serial port. If that photo was better one could see IF the power is really coming from one or two RS232 lines from the computer serial port. I can see the diode, just not where it goes.
Most of the serial to TTL chips need more 5 volt current than most serial ports on computers provide. And for me, a bad idea trying to get power from serial lines from the computer to power RS232 Serial to TTL chip in the programming cable. Newer computer Serial ports do not have enough voltage/current to program some radios. Serial port power IS limited by the serial port chip in newer computers.
Otis413
Cass WVa
Just my 2 kopeyka, if you're going to build you own, add a small "power on" LED (and associated resistor) to the output of the 5v regulator so that you'll know if there is a power problem. You could also power it from a 9v batt or an old 5v cell-phone charger if you want.
Good Luck!
Otis
OFD-14-109
Otsego, MI USA
I will take a better closeup picture of the chip tonight, I still haven’t got the problem fixed yet but I’ve been busy lately and haven’t worked on it much lately.
OFD-14-109
Otsego, MI USA
Here are the close up photos
cmdrwill
So Cali
No wonder, there is a few wrong connections/traces on the board, and missing regulator and diode.
A three legged diode on the left and the regulator on the right in this photo. Post 24 IS the correct schematic diagram.
cmdrwill
So Cali
Any diode should work, even a two leged one. But you will HAVE to correct some of the circuit board traces to make it like the diagram.
OFD-14-109
Otsego, MI USA
Ok I tried to make my own cable still had problems with programming does anyone happen to have a cable they know to work on the tk-*30 series radios I could borrow or purchase. If you would be willing to loan me the cable I would compensate you as well as prepay for shipping.
OFD-14-109
Otsego, MI USA
They make good cables and the price is good. But you can not repair the R232 to TTL chip because it IS potted.
Will this cable work for my 630,730,&830? I’ve never had this much trouble programming a radio but I mainly program Motorola and Vertex radios
Otis413
Cass WVa
It's purdy much just a standard interface cable, I made an adapter from a 6 pin phone jack and an 10 pin edge connector from Mouser to use my kenwood cable to program an EF Johnson radio. It's a great cable for tinkerers.
OFD-14-109
Otsego, MI USA
Ok I ordered one I hope it works it’ll be the 4 cable I’ve been through lol. I like that it is wired for power through the radio instead of the computer so hopefully it’ll work.
