TK-7180 Antenna?
allmjradio
Anderson, TX
I am going to be getting a Kenwood TK-7180 within the next few weeks. I will be installing it myself (I am good with electrical work). What kind of antenna do I need to use? It will be permanently mounted
r_eugene1
Southwest Ohio
Depending whether you are going to use the radio as a base or mobile, there are plenty of good base and mobile antennas on the market depending on how much money one wants to spend on their setup. I myself have used Larsen and Comet antennas and have had good results on both. Below are some links that will give you an idea of what is out there in the way of base and mobile antennas.
Ham Radio Outlet
Amateur Radio Equipment, CB Radio & Scanner Online Sales Dealer
AmericanRadioSupply.com - Ham Radio Store Parts & Supplies - Alinco Amateur Radio Dealer - Comet Antennas
Jetstream
I hope that these links are useful and yo find something in your price range for your application.
allmjradio
Anderson, TX
It is going to be used as a mobile radio
Ham Radio Outlet
Jetstream
allmjradio
Anderson, TX
Well, I chose a different antenna. Instead of the 48" whip antenna I got a 24" antenna that mounts to the roof. The weird thing is, the 48" cost $40 and the 24" cost $3.45
popnokick
Northeast PA
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 5_0_1 like Mac OS X) AppleWebKit/534.46 (KHTML, like Gecko) Version/5.1 Mobile/9A405 Safari/7534.48.3)
The 24" is probably a quarter-wave antenna with no gain, and the 40" might be a 5/8 wave with about 3dB gain... making the price difference.
From the look of the terrain around you (low rolling hills, correct?) you might be best served by an antenna with a bit of gain. They tend to have a fairly flattened out pattern, when compared to the quarter wave, and would be expected to work a little better where you had a good view of the horizon all around. If you were in deeper valleys, with taller hills around, the quarter wave -should- work better (but not necessarily). One thing you can do is take a look at what the local public safety agencies are using. If they are on VHF, a quarter wave will be 16 to 18 inches tall. If on UHF, the quarter wave will be 6 or so inches tall. If they are using 5/8 wave, a VHF will be around 45 to 47 inches, and a UHF will be about 14 inches.
Real world experience will tell you for sure, one way or the other.
Quarter wave antennas are usually cheaper, so it would be a good place to start. If it worked satisfactorily, then you'd be good to go.
You can find the 1/4 wave NMO style antennas pretty cheap, as you discovered. You might even want to look at the specific frequencies you want to listen to and cut the antenna for that. A new antenna should come with a cutting chart. For receive, it likely won't make noticeable difference, but it wouldn't hurt. If most of your listening will be in the public safety bands, you could cut your quarter wave for around 16 inches long. A short quarter wave like that, on top of a car, truck or van, will be lower profile, and less likely to hit trees, parking garages, etc, than a 5/8 wave.
You just need to decide on where and how you want to mount it. NMO mounts are about as standard as you can get. If you start there you will have a wide choice of antennas to choose from.
Permanent mount, magnetic mount, trunk lip mount, fender bracket, etc, you'll have to do what you think you can do. A permanent mount is really nice, looks professional, and if done right, will give you a lot of years of trouble free service. I've installed them on vehicles and they are still working fine after 10 years. Installation is pretty easy, but not for everyone.
allmjradio
Anderson, TX
It appears that all of our trucks use this exact antenna with no problems. We operate on a VHF system at frequencies of 152-160.
Is it safe to coil up 3 extra feet of coax cable loosely?
Yep, just don't make the coil too tight. It would be ideal to cut it to length, but if you don't want to install a new connector, that would be fine. Better would be to find a place somewhere along the run to "lose" that 3 feet, maybe by taking a longer path.
Really, though, a loose large coil should be just fine.
allmjradio
Anderson, TX
Thank's for the reply. I went ahead and just cut it to length, to play it safe.
