TK-7180 random no audio
wsed833
Greenville, SC
I have this radio installed, and I’m using it as a scanner for railroad frequencies. So far, it has been great. However, I noticed today that it is not putting out any audio. No beeps, no audio when a transmission is received, nothing. Scanning finds frequencies and the green light activates when something is received. Again, though, no actual audio from the speaker. I did not change any settings. It is the fuse directly to the battery and I have the additional Block inside the passenger cabin. Is this Electric? Should I recheck my programming? Where should I look?
AM909
Radio/computer geek
SoCal
Does it play the power-on sound? Does it beep in response to any front-panel keys (e.g. volume up/down)? Find some other troubleshooting here: TK-8180 No Audio
wsed833
Greenville, SC
Negative on both answers. Earlier today was working fine. I turned the power off while in the car because I was talking to my daughter, and when it’s powered back on at the next car start, I got no power on beep or any volume beeps. It’s like the speaker is dead or some programming got off whack.
wsed833
Greenville, SC
OK, this is weird. After leaving it on for a while I heard a little pop from the speaker and now everything works again. I’m wondering if there is a loose connection in there somewhere.
Try an external speaker plugged in to the rear 1/8" jack. That'll eliminate the front speaker/flex cable. It'll tell you if the audio amp is working and if it's programmed correctly.
Unlikely that's a programming issue unless you did something with the on hook decode.
wsed833
Greenville, SC
Actually, strike that. Once I pulled the front cover off, it was apparent which ribbon cable. I was making it more complicated by taking the top cover off.
However, the problem persists. I wound up reloading the firmware just out of curiosity and during that process, the speaker worked a few times. I have noticed now that when I press the power button, I get a speaker noise, but no display. I have to hold the power button a little bit longer to get the unit to actually turn on.
This seems like maybe a short? Bad control head?
