- Joined
- Aug 31, 2010
- Messages
- 11
- Reaction score
- 0
need your opinion
I have to plug my Kenwood tk-7360h to vxr-1000. here is the pinout of the mobile radio : 1 SB O Battery voltage output. 1 amp max
2 IGN I Ignition sense input, 16.0V max
3 PA O Speaker output
4 DETO O FM detector output, 500mVp-p
5 DATAI I External transmit signal input, 200±50mVp-p
6 FNC1 I/O Programmable I/O (programmed by FPU), 1.0mA max
7 FNC2 I/O Programmable I/O (programmed by FPU), 1.0mA max
8 FNC3 I/O Programmable I/O (programmed by FPU), 1.0mA max
9 FNC4 I/O Programmable I/O (programmed by FPU), 1.0mA max
10 FNC5 I/O Programmable I/O (programmed by FPU), 1.0mA max
11 FNC6 I/O Programmable I/O (programmed by FPU), 1.0mA max
12 5C O 5V DC power supply, 100mA max
13 HR1 O Horn alert signal output, 16.0V/2.0A max
14 HR2 O Horn alert signal output, 16.0V/2.0A max
15 gnd Ground
and now the pin out of vxr :
Signal Ground 1 Brown (Black) Audio signal ground (usually chassis ground)
Mobile TX Audio 2 Red (Brown) TX audio from the VXR-1000 to the mobile radio
Power Supply Control 3 Orange (Red) VXR-1000 on/off switch
Mobile PTT Output 4 Yellow PTT command from VXR-1000 to the mobile radio
Vcc (13.8 V) 5 Green 13.8 VDC power for the VXR-1000
Mobile RX Audio 6 Blue RX audio from the mobile radio to the VXR-1000
Mobile COR Detect 7 Purple COR signal from the mobile radio to the VXR-1000
Mobile Mic. Audio 8 Gray TX audio from the mobile’s mic. to the VXR-1000
Mobile TX Detect 9 White TX status detect (trunked) or PTT command (conv.)
What connection I need to do ?
15 gnd Ground
