fourbinlabs
- Joined
- Jan 20, 2018
- Messages
- 7
Has someone checked the SINAD of these radios at the bottom of the 2m band to see if there is an appreciable difference?
If you had a K2 radio on APRS, or perhaps as a repeater receiver, and you replaced it with a K radio, would there be a significant difference in receiver performance? Or is being 2MHz outside of the specified range a small enough difference that it wouldn't be noticeable.
Besides, accessing local FM repeaters, I operate an APRS Igate, and would like to also build a mobile tracker to take on road trips. I have a couple TK-780 K2 radios as well as some of the HK version, and am weighing which radios should be used in each application, or whether it really matters at all.
