TK-790 Help
paramedszaf
Kingston, Pa - Luzerne Co.
I recenlty came across one of these units and have a few question hopefully someone here can help me with:
1) If I want to go dual band, single head what kit and do I need to buy anything more than a TK-890(H)?
2) An ANI Board; how much? Hard hard to install for PTT ID
3) What is the antenna connection for this radio? PL-259?
n2mdk
Ames, IA
According to the brochure http://www.prairiemobile.com/Docs/TK-790H_Brochure.pdf
you would need the KRK-7DB and both radios. If you have the 790 then all you need is the 890 and the KRK07DB control head.
See page 3 of the brochure
firemedic2150
Senior Member
Right here...
You will need a KRK-7DB kit and it will come with the jumper cable that goes between the radio's, You will then need a KCT-22 to connect the control head to the radio pair and they come in 3 diffrent lengths. The radio has an accessory port inside that the ANI unit if it is designed for the X90 series should plug right into. And the radio's have SO-239 jacks.
MMc.
vorndamr
Also needed!!!!!
You will also need to modifiy the control boards on the radios as per ther service manual or it won't work. Rod
