TK-790 KRK-6DH audio issue
bobsamuel1844
Hello,
I have a a couple TK-790s with KRK-6 dual head setups. On two separate radios, I have no audio output to control head 2. I understand that control head 2 relies on a separate amplifier within the KRK-6. Is it possible that I just have bad luck and this amplifier is bad in both systems? Or could this be a programming issue?
a417
New symptom, or has this been going on as long as you've had them?
Does it have the Molex connector with the jumper wire on the back of the head that has no audio? That's necessary to send audio to the speaker on the head.
Was the head modified for PA (13 watt) level output?
