TK-790/TK-890 Crossband Repeat
timkilbride
Linn Co Iowa
To cross band the two radios what do I need? Can you program all 160 channels in each radio and cross band whichever two frequencies you want to? I can't find much info on the KRK-4DB.
Thanks for help I can get!
Tim K.
AK9R
Staff member
Super Moderator
Central Indiana
You need one each TK-690, TK-790, or TK-890 plus one of the dual-band kits (KRK-7DB or KRK-8DBH). In the programming, there is a list of repeater pairs that you program into the radios.
I believe the KRK-4DB is for the TK-x30 series of radios.
timkilbride
Linn Co Iowa
So there is no way to hook them up back to back through the DB25 connectors? I was hoping to do something similar I had with two Motorola GM300's. You could select any channel at any time, no pre-set repeater pairs.
Tim K.
AK9R
Staff member
Super Moderator
Central Indiana
It may be possible to create a repeater by connecting two TK-x90s through the accessory port, but the KRK-7DB or KRK-8DBH is the Kenwood way of doing it. Either of those kits is intended for turning a pair of x90's into a dual-band radio. The cross-band repeater function is an additional feature of the dual-band kits.
For whatever it's worth, there's a fairly active Yahoo Group for the Kenwood TK-x90 at:
Kenwood-TK-30-90-Series-Mobiles : Kenwood-TK-30-90-Series-Mobiles
code3cowboy
CA-CZU
It is very easy to do using the accessory port. You can even use a RIB if you want to, and it functions flawlessly.
ramal121
Lots and lots of watts
Calif Whine Country
Maybe you meant a RICK. 'sOK, I brain poof all the time now. I hook TK-X180s back to back quite often through the acc connectors.Works great! The problem with the TK-X90 is the receive COR/TOR logic (high) is bass-akwards from the PTT input (low) and there is no way to change this. You need to provide a level converter somehow (transistor, relay or whatever).
Other than padding down receive audio to mic input, Kenwood radios can be wired together via the acc connector (with the logic snafu taken into consideration),
Motorolas are even easier. Down and dirty is just wires radio to radio. If you want fancy, get a RIB, wait I mean a RICK.
timkilbride
Linn Co Iowa
I have joined the Yahoo Groups. Hopefully I can find a schematic to build a RICK. The time I did it with Motorolas, it was almost plug and play with the directions I had.
Tim K.
