TKR850 will not go into PC mode
garretcanter
Is there a backdoor way to get a TKR850 to go into PC mode? It does nothing when the 1st button is held in and the power button is pressed in.
Steve
n7maq-1
Oregon
The PC mode is entered when you go to read/write, no buttons are need to be held down. Now if you are trying to get into the firmware mode (PG)that is done with PF1 (far left) but firmware programing mode has to be enabled in the FPU.
garretcanter
Sorry I should have said PG mode. It will go into the PG mode program a code plug, but not to update the firmware by using the above method.
n7maq-1
Oregon
Don't feel bad, if you don't mess with programming a lot it is easy to miss or forget. Thanks for the update.
