TLK Series
KG5HHS
D/FW
Hello All,
I'm in the process of doing some research for a possible back up radio solution. My company currently uses Wave Advanced Desktop Communicator (Version 5.19, I think) for dispatch and Wave Mobile Communicator IOS App (Version 4.13) for crews. We also have several repeaters, handhelds, and mobile radios. I would guess these are legacy products as all I can see on Motorola's website is Wave PTX, that also looks a lot more updated than the versions we are using. I have knowledge and experience with CPS from the APX series back to the Astro Saber/Spectra series and the XPR series. However, I don't have any knowledge or experience with programming anything on the wave side.
My question is regarding the TLK series of radios (TLK25, TLK100, TLK110 & TLK150) and how these are programmed. Currently we login with User Name, Password and Server address. Once logged in, that user has access to all "channels" assigned to that profile. When it comes to these radios, how is programming done?
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Assuming your radios are MOTOTRBO units (XPR, SLR, etc), they are programmed with MOTOTRBO CPS and the correct programming cable. You can integrate analog/non-TRBO radios with WAVE, but it is not straight forward (analog/P25 and Vocality, WAVE 5000/WAVE Tactical/WAVE-ON-PREM). The typical setup is some sort of MOTOTRBO radio system, a WAVE Gateway connected to the radio system and the Internet (typically near the Master repeater), WAVE TLK radios, WAVE Dispatch, and WAVE cellphone apps. TT
Firebuff880
Boynton Beach, FL
You log into Customer Hub and from there, you log into Wave PTX Portal or if you are a partner you use Partner Hub.
Either way, it's all done online until you want to connect to/with a MOTOTRBO system subscriber as a Wave Susbcriber as well then you also use the appropriate tool AKA: Radio management as well as the Wave PTX Portal.
