Tones
RadioGuy3007
I am curious about different tones. What do your tones sound like? Do you have an audio file, If so please post it! I am also looking for a tone it goes from Hi to Low to Hi and then dispatch talks. Its from the Motorola Centra Com
That's likely QuickCall2, often shown as QCII. It's pretty easy to find audio clips on the web.
QCII is used for fire station alerting, pagers, etc. We use it at work for paging out fire. In the evening, a radio in the bay is set up to activate the lights in the sleeping areas when the page comes in. It also opens the audio to the internal PA so they can hear the call come through.
RadioGuy3007
This is not the right tone.
The actual tones will vary depending on how they are programmed. The protocol is likely QCII. You would just need to find on that does the low tone/high tone sequence you want.
