Tonkawa OK - Kay County
junktrunk317
I recently purchased a Uniden BCD996P2 for my mom, as she said they moved from analog to digital. I looked up the frequencies in rr db for Tonkawa and manually entered them into the BCD996P2 but I'm not picking anything up.
Does anyone know if Tonkawa, OK did indeed move to digital, is it part of a trunked system or if the frequencies in the database are accurate?
I've searched the internet but can't find anything indicating it moved to digital. All I find is that the frequencies were recently renewed.
Freqed
I'm just a listener
Broken Arrow
Looking at the DB and is shows as analog:
With the 11K2F3E emissions designator in the license:
So not sure how you have it programmed in the radio it's hard to say why it's not receiving anything.
Try hitting the weather button and see if it is even receiving anything and the issue isn't antenna related.
junktrunk317
Thank you for the response. I'll look over the links here shortly.
I did the following to program:
Pressed the Menu button to access the programming menu.
Navigated to Program System and pressed E.
Choose New System and pressed E.
Select the system Conventional and pressed E.
Navigated to Edit Group and press E.
Created a new group by selecting New Group and pressed E.
Navigated to Edit Channel and pressed E.
Selected New Channel and press E.
Entered frequency 154.085 and press E.
After entering the frequency, navigated to Set Audio Type and press E.
Selected CTCSS and pressed E.
Entered the tone frequency 156.7 and press E.
Saved and Exited
