Too Soon For VP8000 Wants/Bug list?
W3AXL
RF Engineer
Indiana
So I've started seeing a strange bug - I'm seeing that about 75% of the time when I boot the radio with an accessory connected (like a speaker mic) it hangs and won't turn off without a battery pull. This is on FW 8.40.13 which I believe is the latest. It hangs on the FW version/radio name screen.
This must be something specific with my radio's configuration, since I can't imagine nobody else is turning the radio on with a mic connected.
otobmark
NC
I tried my radio with KMC 70 speaker mic and had no problems. My radio is the 4096 ch version loaded with all but V-16 trunking. I have DMR installed as well.
As to firmware, the latest is 1.40.14.89 . The 1.40.13 was buggy and removed from the sharefile site, being replaced with .14
otobmark
NC
I use side buttons to change channels and often one press would jump 2 channels. Can’t tell if software or button problem but the work around was to set duration of short press to more than 0, I used .2 seconds. Perhaps making short press more than 0 the default setting in armada would be useful unless the issue is part of a larger problem needing attention.
DeoVindice
P25 Underground
Gadsden Purchase
Sounds like a debounce issue. I've encountered a similar problem with side buttons on VP5/6ks and will see if changing the short press time fixes it.
otobmark
NC
Hope it works. If my radio wasn’t brand new I’d put a scope on the button to look for noise. EFJ should do exactly that themselves to see if they need a new button supplier.
On APX portables I had to buy entire chassis to get new bubble switch. If switch which was a strip adhesively attached to chassis had been available as a separate part I could have peeled off old and stuck on new — job done. Instead I had to strip everything out of old (perfectly good chassis) , reinstall, seal, pressure test new chassis.
otobmark
NC
The fun continues....
I'm on 8.40.18.95 firmware.
Problem/bug--When I use side buttons 2 & 3 for zone up and down, when I land on a DMR zone/Channel the buttons quit changing zones and begin changing channels instead. I have the rocker switch up and down set for channel up and down and if I use it while the side buttons are confused then the zone changes (instead of channel as programmed). If the zone change lands on a not DMR zone/channel then the side buttons begin to operate as programmed until it again lands on a DMR channel. If I reverse the programming using side buttons for channel change and rocker switch for channel change then things seem to work and none of the buttons or rocker become confused when landing on a DMR channel. Also as in a previous post when you land by any means on a DMR channel the radio display will not reflect correct zone/channel of the DMR channel but instead shows last NON DMR channel landed. When you land on a non DMR channel the display begins showing correctly once again.
rescueman433
Just curious…did you set those buttons correctly on what you want in the DMR system. As you can steer buttons different for each system. Just something easy to check and not to offend. Just trying to offer a suggestion is all. I know this as the first time I programmed I didn’t go check and they were not mapped. I assumed they followed conventional system. I haven’t been able to replicate the DMR issues you are having. I have a model 2 radios though. Not sure if we are apples to apples.
Project25_MASTR
Millennial Graying OBT Guy
Texas
That got me on my VM900 once or twice...
otobmark
NC
Wow, you’re really smart or I’m really dumb….. I’m going to go with you’re really smart. I’m used to conventional vs trunked presets but not various conventional.
well, the display issue is real enough. Glad you didn’t start post with “Jane you ignorant sl..”
otobmark
NC
Uno mas…
Would be nice if the voted channel could be displayed so you would know which site you were using. Not vital but nice.
otobmark
NC
DMR receive group talkback timer.
When talking direct and receiving a talkgroup in the receive group list I seem to get 5-7 seconds to talkback on the received group TG. If I'm using a repeater then the timer is maybe 2 seconds to talkback before radio goes back to normal talkgroup.
what's needed is a set-able talkback timer for RECEIVE GROUP talkback.
AM909
Radio/computer geek
SoCal
LTR
(I'm just throwing this out there, out of respect for the ghosts of EFJ, CW, LM, RB, and the rest. Please don't explain why it won't happen. I know. )
