Tower identification
Jackets
Ontario, Canada
I am looking to get a make and model of a tower i was given (5 sections)
i have no exact specs as it was something i came across while out with my girl.
Its made of Aluminium
Sections are Square not triangular
Sections are roughly 10-14" wide
Sections are 8-10 feet long
Structural webbing is very similar to the Rohn 65G one rod multi bend layout
Joints do not slip together but are stacked and 2 locking plates bolt together similar to the 65G i cant tell on the 65G if the 4 bolt joints are welded in place or free to move, this tower is free to move/spin he joint for easy alignment. one set is circular with 4 bolt holes, the rest are 2 bolt units
Hope to pick it up today but im not optimistic i will have time, i will have photos at that time though.
Picture would help.
Are you sure it's a radio tower and not truss for theatrical lighting? 4 sided and aluminum sounds a lot like the truss stuff a friend of mine uses for lighting support.
Jackets
Ontario, Canada
Tower sections are 10' long and 14" square.
So 50' in total plus whatever i fab for a base and top.
Pictures attached
Cheer all!
Wow, that certainly is a tower. Not something I recognize. Should be interesting to hear from others.
Golay
Nankin Township Michigan
Scaffold?
I'm wondering if this is scaffolding. First off it's wide enough to fit a 2 by 12 between the legs. Second it looks like paint on the black sections, like maybe someone was painting on a scaffold.
Jackets
Ontario, Canada
Base colour is not black or orange, its more of a whiteish, the black is something someone has put on afterwards, its quite thick but not as thought it was sprayed like a gun would produce.
The orange is sprayed but at a better quality but still far from great.
The rungs do not line up enough to allow a flat lay across both sides at once and i would doubt the strength for a safe WLL with the board sitting on a single rung as they are aluminium and i can flex them with my foot.
Interesting though though
majoco
Stirrer
New Zealand
The orange colour is a hint that it might be from an airfield - lighting tower or a glideslope mast perhaps?
MisterLongwire
Amateur radio operator/QC tech for radio mfr.
San Marcos,Escondido, CA.
Ok...admit and fess up...what airport have you visited lately?
Folks...that tower is from an airfield...ie:airport.....that probably held ground radar dishes or antenna. Looks exactly the same as the stuff they have at LAX. Hmmm...maybe I should drive back and see if any are.missing...
Jackets
Ontario, Canada
Interesting, i have noted a tower base that looks like a match but i will not be walking in to have a look as its located on the local Military base.
At least i have an idea where its used.
Thanks all.
