There are superhet SDRs, so you really have to distinguish between an all analog hardware radio vs SDR, which comes in many different flavors.
Correct. Yaesu FTdx-101D is an SDR receiver with IF filters in front of it. Same with the Elecraft K4HD (expected by end of year). Where you will see a benefit of those radios over straight SDRs is in a multi/multi or Field Day environment. Unfortunately (if you read the reviews) the ergonomics of the 101D are less than good (being kind).
I have a Flex 6600M I will be using at Field Day this year. The second station will be a 6600 and the third again will be a 7300. The 7300 will get nailed with overload but the two 6600s should be fine @ 100 watts due to the 7th order bandpass filters. The 7300 TX phase noise is not too good for a multi/multi configuration so we will make that station use antennas further away from the other two stations. Also the 7300 will not be allowed on the same band as the other two stations.
