Transmit Power testing
Hello my friends. I have this communication system. Microhard - pMDDL2350 Development Kit
It went through some harsh weather condiitions and some times does not do its job. It abruptly disco nnects with the second similar system, that it is paired with.
Can you please tell me how to measure the transmit power for this system from its antenna port?
I mean to ask you, what equipment do I need to measure the transmit power for this system from its antenna port?
Thank you my friends.
prcguy
It appears the system operates around 2.3GHz. You would need a power meter for that frequency range that can measure down to maybe 10dBm and up to 30dBm both peak and average as its probably digital modulation with less than 100% duty cycle.
Here is a cheap meter that should work but it doesn't mention if it can do peak power. It will measure up to 0dBm and you would need an external 30dB attenuator to allow measurements up to 1 watt.
