Travel to Decatur
Gasman315
Wis
Hi Group
I just found out I have to travel to Decatur Ill on Sunsay. I will be entereing from Wisconsin on HYW 39 . Does any body have anny USAD files for Police and Fire freqs. I could program traveliing through the state. A List of counties with cities off of 39 could also be used to program. I realize this is short notice and i am not a member of the Ill group,but any help would be greatly appreciated.
Nate
soncorn
Fort Worth, TX
One interesting thing that I can recommend is that you program in and try out the new Illinois "statewide" system. It is not even close to all being up and running, but you should pick up a lot of traffic around Bloomington-Normal where 39 intersects 55 and 74.
Here is a link.
http://www.radioreference.com/modules.php?name=TRSDB&sid=2324
Beyond that just look in the databases. I believe that Decatur is in Macon County.
daleduke17
Bloomington, IL
Coming down I-39 to Decatur will take you through several counties. Some of mention (with cities included that I can remember) :
Winnebago (Rockford, Loves Park)
Ogle (Rochelle)
Lee
LaSalle (LaSalle-Peru, Streator)
Livingston (Pontiac)
McLean (Bloomington/Normal, Heyworth, Hudson)
DeWitt (Clinton)
Macon (Decatur, Forsyth, Mt. Zion)
That is I-39 from the Wisconsin border, in order, to Decatur. I live in B/N and used to drive to Monroe, WI about once a year, so I got used to that highway. When you get into either Ogle or Lee, look for the big wind farm around the interstate. Really cool to look at.
What takes you to Decatur?
Gasman315
Wis
Thanks for the county info. I am traveliong down for work and looks like I mightr be heading into bad weather.
K9JLR
McDonough County, IL
A few IL State Police Freq's to monitor:
42.500 MHz - ISP Weather Warnings/Car-to-Car
155.460 MHz - Illinois State Police HF4
155.475 - ISPERN
42.440 MHz and 42.700 MHz (District 16 State Police)
42.460 MHz and 44.700 MHz (District 17 IL State Police)
42.360 MHz and 155.520 MHz (District 8 IL State Police)
42.520 MHz and 42.720 MHz (District 1 & 6 IL State Police)
42.540 MHz and 154.695 MHz (District 10 IL State Police)
LaSalle County uses 155.700 MHz highband at times. LaSalle County SKYWARN spotters use 147.120 MHz repeater in Leonore. McLean County is using Starcom 21 digital comms. Check the RR database for Decatur listings.
Gasman315
Wis
Thanks for all the help. I arrived here in time to beat the storms by one hour. Thanks to all who helped as I was able to miniter all the counties that were given to me. I did see all the wind towers inPapaw. Your multi tower system(STAR) was only active on McClain County and Normal Pd.Thanks for all your help as it enabled Me to follow the responses to the storm on the way down.You ever travel to the UP of Michigan and have questions Ler me know!!
Nate
Gasman315
Wis
Storm Spotters were not as active as the Sheriff and county Fire. Decatur Pd & FD busy. Overheard alot of Red Cross trafiic on MAABAS channels on the trip home.
daleduke17
Bloomington, IL
A small town about five miles from Decatur had a touchdown that destoryed part of a restaurant.
A couple other parts of Macon County got hit as well, right around Decatur.
