TRBO USB programming cable driver issue
Anderegg
Enter text in this field
San Diego
Trying to update some MotoTRBO radios, but the driver for the USB cable will not install Working on a Mac using Bootcamp. Tried my Parallels install, which works, but I cannot clone my codeplugs because the firmwares need to be updated, and you cannot update firmware using Parallels because the device disconnects and errors out when the radio reboots itself into Flashzap. This is driving me nuts. I have installed the old 2012 era MOL 5.0 driver, no dice. Uninstalled everything, reinstalled, no dice. Any suggestions other than buy a new Windows laptop to flash some mobiles? :(
Paul
Anderegg
San Diego
Correction, the MOBILE cable works, but the PORTABLE TRBO/APX cable DOESN'T. Cable works in Parallels and on Bootcamp with APX, so I know the cable is fine and the radio is a 6550, which this cable revision works with as well as the 5/7000 series.
Paul
YL3IM
KO26BX
It's a known problem. There is no way to use CPS with Motorola on ARM64 right now, for the lack of drivers. Choose an x86 architecture PC instead.
Anderegg
San Diego
Bootcamp is not ARM64, its Windows 10 64 bit x86 run natively on Intel CPU. I tried a Windows 11 64 bit real PC, and it gave the same error shown in device manager. I then installed all the TRBO stuff on my old Windows 7 Astro Saber/DOS DELL laptop, and that worked flawlessly.
Paul
gman1971
A long shot, but perhaps enabling Legacy USB device support on the BIOS...
Anderegg
San Diego
Unfortunately, there is no BIOS for Bootcamp systems.
I thought my days of keeping an old Serial port equipped Dell around were behind me. o_O
Paul
