TRI-152 vs TCA 152a
E5911
the lower desert
H all
Saw both radios on Airsoft forums, The tri radio appears to be a UV5r in a fancy package with a great battery. Not sure about the TCA. different display. Will take a GPS board or something,
Does anyone know about the TCA 152? It does not appear to be a beofeng clone
Just curious
rescuecomm
Travelers Rest, SC
The TCA-152 is the latest version and supposedly can use the mbiter accessories without mods. It has the aluminum housing. The TRI-PRC-148 is about the same but ships with a Thales battery and is more expensive. These radios don't have any type approvals so use them at your wn risk. Someone on M4Carbine.net has a writeup.
Bob
baltimorecs
Baltimore, MD
These radios are based on an older model made by a company called Baojie. I made some programming cables for one of the PRC-152 clones made by Triumph Instruments (TRI.) It used the Baojie software to program them.
There is a Facebook group dedicated to the radios here, which is where I found the info to mate the USB to a real PRC-152 cable for programming (pinouts are all different.)
laythrom
Warren, Ohio
Any chance you recall the FB group where you got the pinout information?
