All was good in connecting to SDS200 for upload/download connections to SD card in ProScan and Sentinel. Firmware updates OK. Database updates OK. Connections to Uniden and RadioReference databases OK in both apps.
I was messing around with ProScan and controlling the scanner through the virtual control window. I got it to connect in serial mode over USB port. Was fine but I messed up USB connection to read SD card somewhere in the process of changing port stuff.
I got a new SDS100 hours after I messed with controlling the SDS200 and altering port configurations. I plug in the USB to WIndows 11 laptop and the SDS100. I hear a ding on the laptop when it plugs in, but no popups on the laptop about SD and the scanner does not switch to the screen where it asks id you want serial or mass storage connection on the scanner.
SD card is fine. Scanner loads channels and scans.
Ugh... Everything was good until I switched to serial mode.
I must have messed up USB/SD settings. Please help!
