Trouble with F60V Programming
uscgccushing
I'm attempting to program a set of new F60V radios, and I'm running into a "No answer from transciever" issue when I try to write to the transciever. I'm able to read from it and get information with no issue, so I don't think it's the anything physically not connected. I have no idea why it would let me read but not write. Can anyone shed some light?
Thanks in advance!
W2GLD
Southeast Michigan
Make sure you are using the correct firmware/cloning software combination... Current release is v3.1.1
Also, make sure the radio is connected and turned on first. Then read the radio, archive the cloning file as the original and then edit a version of it for your needs.
uscgccushing
Looks like I'm using v3.1. I had a hell of a time finding that one... Do you know where I can get 3.1.1?
I tried following the steps you listed, but am still having issues. I read the file, and then made one small change (turned on a short opening beep), and tried to write. No beans.
