Ct052
Hello, I will be programing a scanner for someone who is moving to Trumbull. Since I am not in the immediate area, I have a few questions about Trumbull Fire. Is their dispatch from CLMRN patched through to their low band or high band frequencies listed? The CLMRN database shows that there are operations channels. Are these channels through the trunked system only or are these talkgroups just rebroadcasting analog conventional channels back to the trunk system? If conventional analog like other departments do, are the frequencies listed as fireground in the database still correct with the new system? I did read that they have tri-band radios, which leads me to believe this is the case. I will submit new data when someone can confirm exactly how their system works.
