trunk lip antenna
unit479
is there anyway to properly install a k40 trunklip antenna thru the back of a crown victoria without
tearing out the back. any easy way?
steveh552
Canal Winchester Ohio
the antenna should slide right onto the trunk. If your talking about running the coax, I always pulled the back seat out and run it through then put the seat back in.
mcema699
Reach under the back of the seat where the back and the bottom cushions meet. Find the bottom of the cardboard or insulation sheet or poke a hole in it. Run a coat hanger or other stiff wire up into the trunk. Crawl in trunk and find wire. Tape coax to wire and GENTLY pull back into car. Sometimes you can start in the trunk and then find the pull wire inside. Protect seat covers with towel or blanket to keep clean while doing this. If you leave any connectors on the coax for the pull through, don't put too much of a strain on them and cover them with something to keep them clean during the pull also.
If your rear seat folds down for access to trunk, its a whole lot easier. :)
This worked for the GM cars I've had, I think I may have done other makes when I used to work retail and had to install a few.
unit479
Thanks For The Info. a couple of gm cars was fairly easy. if any other problems. i'll post.
stevolene
chattanooga metro
I get my wife to get into the trunk, I run a coat hanger from the top right hand side of the back seat, comes out about where the drivers side trunk hinge is, she ties on the coax and I pull it through.......
