Trunk Recorder Broadcastify Upload Failed
kktrum
I'm using trunk recorder to record and then try and stream the calls it records to Broadcastify. I have Trunk Recorder setup and it's working, however, the uploads to https://api.broadcastify.com/call-upload are failing with the following error from Trunk Recorder:
[2022-09-11 19:09:44.510450] (error) [TTU] TG: 603 Freq: 8.564375e+08 Broadcastify Metadata Upload Error: <html>
<head><title>502 Bad Gateway</title></head>
<body>
<center><h1>502 Bad Gateway</h1></center>
</body>
</html>
I'm using Trunk Recorder in a Docker container on a Raspberry Pi, any ideas on how to fix this or if it's an issue on Broadcastify's side?
