trunk-recorder cannot decode P25 Phase 2
CqDx
US
Hello,
I have been using a Raspberry Pi 3 B+ with trunk-recorder installed and it’s doing a great job on decoding and recording P25 Phase 1 traffic, but when the network recently started carrying Phase 2 traffic, all it records were garble and unintelligible traffic. I see the logs reflect it recognizes TDMA traffic but it just would not record Phase 2 intelligibly.
Anyone has experienced this as well and if so, what was your solution?
Thank you!
GTR8000
NY/NJ Database Guy
BEE00
Experienced the same with a fully TDMA system. Was mentioned by the developer that it's possible there is an issue with decoding TDMA on ARM hardware. I'm glad you posted this, as it confirms what I was experiencing. Hopefully they'll be a solution for it. Make sure you post this on GitHub also.
CqDx
US
I had no issue decoding and recording it on SDS100, I’m inclined to try a different Linux machine just to see if it’s ARM hardware related
GTR8000
NY/NJ Database Guy
BEE00
MRRS/Metro-25? Let me know how you make out if you try non-ARM hardware. Right now I only have the same 3 B+ available for testing, and obviously that hasn't been successful with TDMA for either of us.
CqDx
US
Yes and also NJICS on Alpine and DOITT P25 site also. The same problem across Harris, Motorola - ASR and Simulcast.
GTR8000
NY/NJ Database Guy
BEE00
Okay good. I mean, not good, but good that it's not an issue with just one TDMA system. And you having success with the FDMA talkgroups on those systems is also reassuring.
wgbecks
NE Wisconsin
I don't think the issue is ARM hardware. OP25 decodes Phase-II TDMA perfectly on the same hardware.
GTR8000
NY/NJ Database Guy
BEE00
Right, but Trunk Recorder uses its own build of OP25.
jonk6
You might want to grab the latest TR from GitHub. It includes a fix for this issue.
CqDx
US
I can confirm that with the latest update on trunk-recorder this issue has been resolved. !
mikewren
Albany, NY
Can confirm the update from May works terrific on P25 Phase II TDMA. Thanks!
