Hello,
I recently purchased a Pro-651 and can't seem to receive transmissions when scanning Trunked Systems. I tried this in two locations with the same results.
The first Trunked System is "State of Delaware Public Safety" New Castle County. I first manually programmed the control channel and both alternate channels in Scan List No. 1. I left the default Talkgroup as "Wildcard" as it's my understanding that all Talkgroups on the system will be monitored. No transmissions were received. I verified that Scan List No. 1 was on.
I then added the remaining voice channels in my area to the Trunked System. Still, no transmissions were received.
I then substituted Talkgroup "Wildcard" with specific Talkgroups in my area. No transmissions were received.
I then tried a search using the lower and upper ranges of the Trunked System and DID receive transmissions. Some of the transmissions were clear and some were encrypted.
Question 1: Is "State of Delaware Public Safety" a 3600 system?
Question 2: Both of the Trunked Systems that I tried to scan have been rebanded. Does this model require a custom table entry? I entered the following custom table with no success:
ChLO ChHI Step Offset Base
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
Question 3: I've verified that the L/O list is empty. Are there any other settings that would cause this issue?
Programming cable is in the mail...hopefully that will give me a better understanding of the issue.
Thanks!
Thanks!
