Trunked Systems @ RDU...
b52hbuff
I'm doing a radius search of RDU to see what there is to listen
to at the airport. There appear to be at least 2-3 more systems
than are listed at www.radioreference.com.
The first system is a 400MHz system assigned to Midway Airlines. The
callsign is WPST366. Go here:
http://svartifoss2.fcc.gov/reports/callsign.cfm
and enter the callsign above.
The output frequencies are:
451.8375, 461.3875, 461.4625. 461.7875, 462.1375
So for you local listeners, is this trunked system active?
Chris-M
nada
No control data on any of those freq's. I will try later (it's 4AM as I type this!) :shock:
Chris-M
At 10:30 AM, no activity on any of those frequencies. Silent.
I listened for 10 minutes, and no data, nor any coversations.
It may be a very low power system. I am pretty close to the airport on high elevation so I should hear something even if it were low power.
KE4ZNR
Radio Geek
This system went silent when Midway pulled out of RDU Airport awhile back...hope this helps!
