WuLabsWuTecH
- Joined
- Jan 20, 2008
- Messages
- 197
So there isn't currently a voice pager on the market that can handle trunking and alerting like a minitor does. But I am wondering, why not? I have an engineering background and I was thinking that if a Uniden scanner can sit on a talkgroup, and a Uniden scanner can decode tones, then certainly taking the next step to sitting on a talkgroup and decoding tones isn't that far of a jump is it?
I figure that if you don't need all the bells and whistles of a full motorola radio or a full scanner, you could probably fit all of the electronic components into a smaller case the size of a minitor right? And program it to sit on a Talkgroup and listen for tones, and open the squelch when it hears the right set of tones? Clearly I'm missing something because it can't be this easy or else it would be done already. But all the departments I know that have gone to 800 MHz all simulcast onto VHF or Low Band to activate minitors, and then then sit a base station radio on a special talkgroup (e.g. Station 123 Page) which is patched to the dispatch TG when that station is needed.
It seems like building a smaller circuit board and sticking it inside a minitor sized case would be a more cost effective measure? And if they can sell Uniden Scanners for about $300, I would assume you could build a pager and sell it for about the same right?
The only reason I can think of that it hasn't been done is that most systems are eventually going to move toward digital and since digital systems can't do toned paging (because of the signaling mechanism where the tone is not technically continuous and therefore would be very hard to decode) no one wants to build one to fill the gap of a decade or so before digital will be the norm?
