Minitor V homemade programming cradle.
darkstaractually
I have a couple of old but still working minitor 5 charging cradles. Would it be possible to convert one into a programming cradle by moving the pins to the correct TX, RX and GRND positions in the cradle to correspond with the contacts on the pager then soldering a cut and stripped USB data cable's TX, RX and GRND to the pins? Forgive me if this is a stupid question, I'm not extremely familiar with this.
Thank you in advance!
n3obl
ØAES-1056
PA
not just a USB. you need a TTL level convertor.
n3obl
ØAES-1056
PA
Best advice is to use the GRE scanner cable. It has the ground and RX/TX data lines. just pop an TRS jack into the cradle.
wa8pyr
Staff member
Lead Database Admin
Ohio
I did this with a programming cable that had no interface; I just added a 1/8" stereo jack to the programming cradle and wired appropriately. Works like a charm and only cost me a trip to the junk box and a few minutes of soldering.
