BCD325P2/BCD996P2: Trunking on BCD325P2
CrazyRach82
I am trying to set up trunking for a local T3 System, Manchester Airport.
I have managed to find a few frequencies of this system, and have found out the information using dsdplus.
The information in DSDPlus says its Tier 3 Std, Auto. The colour code on all the systems is 0.
I have posted a screen shot below which shows my event window.
The problem is that from this screen shot, I am presuming the LCN is 50. But it seems to be 50 on both slots, and on all frequencies.
Or is this not the LCN?
Any help appreciated.
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
Incorrect, the 50 encircled here denotes priority as described here, take note of the "Pri" column header in your screenshot
CrazyRach82
So how do I find out the LCN of this particular channel? Also I have noticed there is no network id either.
Thanks for your reply
Whiskey3JMC
I've never seen net ID and Ch IDs not come up upon voice traffic on a TIII system before (at least the ones monitorable to me). If you had the channel IDs you could use this LCN calculator to help determine the LCNs but not sure why the info isn't coming up. If you had a Uniden x36HP or SDSx00 you could also run the built in LCN finder to determine LCNs
cg
Connecticut
That screenshot is identical to what I see on a voice channel when I manually tune to one, no SYSID, no Site ID. Have you tried all the frequencies listed on the DB page for the old MPT system?
Keep searching for that CC.
chris
devicelab
Radio N.E.R.D
WA (USA)
You're in the 'scanner' trunk-tracking mode of DSD+ and that's not the best mode for the information you're looking for. You're not seeing the LCN because the 'scanner' is on a voice channel.
I'd suggest watching a few youtube videos on how to use DSD+
cg
Connecticut
When in scan mode, the word "Scan" appears in the top margin of the FMPx window. Not seen in post 1.
