Trunking System Question
mocofeed
I have multiple trunked systems in the P25 Trunking System Manager part of the software. Why aren't all of them showing as options when I look to add them to a Zone? All are within the correct frequency bands.
Did you import them from the system manager to the profile, before looking for them in E7?
mocofeed
that's where I'm running into issues - sorry, should have been more clear
mocofeed
are all your systems added in E2?
I'm not getting that option, despite the system I have in resources being within the correct frequency band. When I click "Add" some systems show up, but not all.
You first import them in C1, from RR if possible, then open the profile you want to edit in E, next go to E2 and import the system from C1
Using Add System from Resources, repeat for all systems, then go to E7 and select the type (IE: Trunking TG Scan) and then they should show up.
mocofeed
When I select "Add System," the one I selected in the previous step is not showing up. Other systems are, but this one is not.
mocofeed
I am importing to the first step from RR. Then, when I try to add within the profile, it’s not among the options.
What model of the pager do you have and what system are you having trouble with? I'm thinking there may be sites with frequencies not compatible with your model which prevents it from being available in E2.
mocofeed
G3, the West Virginia State Interoperable Radio Network. It’s UHF. There’s one site that I’m aware of that’s an outlier in terms of frequencies but the one site I’m monitoring is within the correct band.
Then when importing into C1 remove (don't select) that site. Plus double check for others.
This is the site. It would be compatible with any G3, right?
Appears to be. I'm at a lose what the issue is, sorry, I haven't run into the issue.
Last thing, post a screen shot of it in C1 and post the availability in E2 add Resources screen.
Perhaps you can reach out to the dealer.
mocofeed
This is above my head, but I know these are out of my unit's band split. Can someone explain? Mine is 450mhz to 520mhz
SIRN P25 Channel ID Table
CH ID Type Base (MHz) Spacing (KHz) Transmit Offset (MHz)
4 FDMA 450.00000 6.25 +5
5 FDMA 400.00000 6.25 +9
6 TDMA 450.00000 6.25 +5
7 TDMA 460.00000 6.25 +5
