Trunkrecorder one-touch setup
dloydradioref
Odenton, MD
Just want to share what I wrote to help anyone trying to get trunkrecorder up and running
Trunkrecorder one-touch setup with Raspberry Pi running Ubuntu,. RTL-SDR, and configures OpenMhZ, Broadcastify, and RDIO.
This system is a comprehensive one-command deployment solution for P25 trunked radio monitoring that completely automates the setup of a Raspberry Pi with RTL-SDR devices. Here's what it does:
The system automatically connects to RadioReference.com using your login credentials, downloads live talkgroup data and system configuration for any P25 radio system (you just provide the System ID from the RadioReference URL), then intelligently calculates RTL-SDR requirements by analyzing the frequency span and automatically configures 1-3 RTL-SDR dongles with optimal center frequencies. It generates a complete Trunk Recorder configuration, sets up multiple upload services (Broadcastify, OpenMHz, RDIOScanner), installs all dependencies, compiles Trunk Recorder from source, creates systemd services for automatic startup, and establishes nightly automatic updates that refresh talkgroup data from RadioReference to keep everything current.
The entire process requires just running sudo ./master-build.sh, entering your RadioReference credentials and system ID, and the system handles everything else - from hardware detection and driver configuration to service management and log rotation. It's designed for production deployment with security hardening, automatic cleanup of old recordings, and comprehensive monitoring capabilities.
doctorwizz
MD
Amazing! Have to dust off my Pi and try this.
Will TR run on Pi 2b?
dloydradioref
Odenton, MD
I don't know if it will work on a Raspberry Pi 2; that may be a stretch. I just updated the script so it will detect the OS that it is being run on and give all the options to install TrunkRecorder. I've tested the running on A Raspberry Pi 5 running Ubuntu, and have tested on a regular Ubuntu system. I'd love to hear if anyone has luck on any other system. The biggest thing it does is generate the configs needed for trunkrecorder.
n1iic
Geek
NH
It's written in Linux bash script and Python.
You could dual boot your machine, pick up a small computer or a Pi 5, the more ram the better.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Very nice, I haven't looked at it but this is something we're going to build into our Pi image (this functionality) - we're going to pair it with P25 survey as well which is going to get us to pretty cool deployment tool for this stuff...
