TrunkView MPT1327 question
OK2BCK
New Zealand, Napier
Greetings
Does anyone know why is my TrunkView displaying 'Statistics' window the way I cannot read it? On it's homepage is shown readable.
Comint
Queensland, Australia
Greetings
TrunkView uses the 'Terminal' font, size 8pt (without BOLD attribute).
People having this problem in the past, have had a corrupted font, or were missing the font from their computer.
Re-install the font, or repair it, and everything should be back to normal.
Comint
Comint
Not even a default WinXP font.
Works OK on my system using WinXP.
Was the problem up on RR forum?
Can't remember, but there is an MPT1327 forum elsewhere on this Site
The following comment, copied from the TrunkView Group on Yahoo, was in response to the OP stateing that he couldn't find the Terminal font anywhere on his computer.
> Terminal is a monospaced font (as opposite to True type).
> The font resides in vgaoem.fon and 8514oem.fon - both files should be
> present in your \Windows\Fonts folder.
> To check:
> Open Notepad and select Terminal as Font.
> If you can type readable text you know the Terminal font is installed OK.
> Gerrit.
Comint
