TRX-1 Change Archive File Location ?
BrianG61UK
England
Good question.
I assuming you have no trouble navigating to a different directory each time but, like me, would like it to default to your chosen directory every time rather than to "My Documents"
yeg_scan
Canada
Searched the registry .. found nothing that makes sense. So likely we are out of luck on that one.
budevans
Cleveland, Ohio
How do I change where the file is saved when "saving current configuration to archive"?
I'd like to know the answer to that question.
For some unknown reason it tries to save to OneDrive, instead of My Documents. I have to manually select the TRX-1 directory in My Documents each time.
budevans
Cleveland, Ohio
I believe it's using whatever you have set as default directory for documents in Windows.
/Ubbe
No, I have never set OneDrive as a default drive. My Documents is my default documents drive.
EzScan is the only program that defaults to OneDrive.
jnlannon
NK2J
Mesa, AZ
Same problem here; it chooses an old documents folder from when I first set up Windows, but it’s not the only program I use that does that.. My workaround is to create a shortcut to where I want to save the archives. One small caveat is the programming library that Whistler chose doesn’t allow me to simply double-click it to navigate there. I have to right-click and choose Open, but it still works and saves a few clicks.
