Unitrunker How to View UT Log
TexScan780D
If you use the Zadig that comes with SDR# v1920, it will give you the correct driver for the genuine RTL-SDR.COM Blog V3 and V4 because it will add the 261KB rtlsdr.dll Application Extension for you.
Buy RTL-SDR Dongles (RTL2832U)
I don't have enough experience with trunking to tell you which device is best for you. However, if you use the V4, your Device Manager should look like this, showing Blog V4:
Zadig is difficult to use. I can give you step-by-step screenshots.
Yes, please.
rabbit108
S.E. VA
RTL-SDR.COM V4 Driver Using Zadig in SDRSharp v1920
I first checked my Device Manager to see what SDR device driver was installed; it was for a NOOELEC V5. I could have uninstalled it, but decided to see if Zadig would be able to replace it.
Download a fresh copy of SDR# v1920, unzip to folder there, and rename:
More after lunch.
rabbit108
S.E. VA
to continue:
Open SDRSharp v1920 Folder. Note there are 20 items. Click on install-rtlsdr.bat while connected online:
Run anyway:
Press any key:
Note there are now 2 new items added, the rtlsdr.dll Application extension and Zadig. Click on Zadig:
More later.
rabbit108
S.E. VA
To continue:
This is where Zadig gets tricky. What you want to see is Blog V4 listed as a device so that you can reinstall its driver.
Well, this isn't very helpful. Try unplugging the V4 and reinserting it in the USB port. I use a short USB extension cable.
This is a little better, Click on Options:
Click on List All Devices:
Click on Reinstall Driver:
More later.
TexScan780D
Thank you Rabbit108, I really appreciate you in doing this for me. I will check this out on Saturday.
rabbit108
S.E. VA
You are most welcome. I appreciate the positive feedback.
To continue just a little more to be complete:
Blog V4 now shows in Device Manager:
Open SDRSharp:
It shows wrong Device. Click on Menu:
More after lunch.
rabbit108
S.E. VA
To continue:
Click on Source and select RTL-SDR USB:
Software shows correct tuner for Blog V4:
Click on Layout and Zoom Bar:
Hide Taskbar to show Offset setting at bottom of Zoom Bar:
Click on Play triangle and adjust RF Gain and Zoom Bar Controls:
Happy Hunting!
